Here is a presentation of the Flux environment; the project management, the data management, the command language, the
formulas and mathematical functions.
The construction of a Flux project consists of several stages: Geometry → Mesh → Physics → Resolution → Postprocessing;
with the possibility to import a CAD file, a mesh, materials...
Flux Skew is a module dedicated to the analysis of rotating electric machines with skewing, allowing a straightforward
geometric and physical description in 2D and the consideration of continuous or step skewing effects.
Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also
provides RLC extraction and generation of SPICE-like equivalent circuits.
The Material Identification tool is based on the Altair Compose environment and allows determining from measurements
the parameters and coefficients required to create a material in Flux.
AMDC is a comprehensive material database maintained by Altair and partner suppliers of engineering materials. Ready-to-use,
Flux-compatible models may be obtained directly from this database for a growing number of materials.
This documentation deals with the Jython script used in Flux and allows to understand the various structures of
entities and functions, and use it in user scripts for example.
This section deals with the display of magnetic properties
of a material through curves and, in the case of magnets, through graphical entities
(isovalues and arrow plots).
