Editing a Process
Once you have configured and saved a process, you can edit it at any time.
To edit a process
On the Navigation Tree, click Automator and select Standard Processes.
Click the name of the process you want to change or clicking anywhere on its row, and then click
When you open a saved process for editing, the following additional tabs become available on the Process Properties page:
General tab: Allows you to specify general settings.
Advanced tab: Use this tab to specify advanced settings.
Job Disposition tab: Use this tab to specify job log disposition settings.
Monitoring tab: Allows you to specify input file monitoring settings.
Script tab: Allows you to add, view, or edit a process-specific script.
Schedule tab: Allows you to specify process schedule settings.
Rights tab: Allows you to assign process access rights to other users, roles or groups.
Alerts tab: Allows you to define process alerts that will only act for the current process. Process alerts act in addition to global alerts. Adding and use of process alerts is identical to global alerts adding. Refer to Alerts section for details.
