Scheduling a Process
After adding a process, you can create a process schedule to specify when, and at what interval the process will run. All schedules used in the system are listed on the Schedules page. You can add, edit or delete the schedule on the Schedule tab of the process page.
To open the Schedule tab
On the Navigation Tree, click Automator and select Standard Processes.
Click the name of the process you want to change or clicking anywhere on its row, and then click
On the displayed page, select the Schedule tab.
To suspend the selected process
Click the Suspend Selected button.
To resume the selected process
Click the Resume Selected button.
To suspend all processes
Click the Suspend All button.
To resume all processes
Click the Resume All button.
Note: If the process fails to run, see When a Job Fails to Run for possible explanations.
