Specifying Scripts for a Process
On the Script tab you can create and edit the global environment and process scripts.
The following scripts are displayed on the page:
PreProcess tab: Specifies process-specific, pre-process declarations.
PostProcess tab: Specifies process-specific, post-process declarations.
Global Declarations tab: Specifies Dim statements or other statements that must be global to the entire script module.
References and Imports tab: Specifies additional .NET assembly references and namespaces required by the PostExport, PreExport, and Global Declarations tabs.
Passwords tab: Specifies passwords for use in password macros.
NOTE: Automator users can only edit these scripts if they are granted editing privileges by the Admin.
