Activating Monarch using an Activation Code
The Activation Code is also referred to as a License Code, License Key, or License Number. It is an 18-digit code that you must specify in the Activate License screen of License Manager to activate Monarch. This key should have been provided to you if your copy of Monarch was properly purchased.
IMPORTANT: Activation codes for Monarch v2022 require an internet connection for periodic license verification.
For Monarch installations activated by online activation, the license check is performed every 14 days.
For Monarch installations activated by offline activation, the license check if performed every 30 days.
For Monarch installations on a virtual machine, the license check is performed every 24 hours.
When a license lease (i.e., the time between two verification instances) is about to expire and no internet connection is detected, the following message displays:
If you wish to verify your license, ensure that you are connected to the internet prior to clicking "Yes" on the dialog.
If your license expires and no internet connection is detected, the following message displays:
To continue using Monarch, simply connect to the internet to verify your license.
If an internet connection is not available, contact Altair Support.
