Export Design Window
The Export Design Window allows you to view or edit existing exports.
To access this window select Export Design on the Export View ribbon. Note that different panels and tabs displays depending on the source view and output file type.
Table View
This panel displays if you select an export that uses a table as its source..
   Field  |
   Description  |
   Description  |
   Displays a description of the current export (e.g., "Export the table data").  |
   Select Filter  |
   Selects the filter you want to apply to the table or summary. Select the All Filters option to apply all of the available filters or the No Filter option to apply none of them. If you choose the All Filters option, specify the desired Automatic Naming setting:
   Sort Order  |
   Applies a sort order to the data you are exporting.  |
Summary View
   Field  |
   Description  |
   Summary drop-down list  |
   Selects the summary that you want to export. Select the "All summaries" option to export all of the available summaries.  |
   Automatic Naming options
   Specifies how you want Monarch Complete to name the export:
   Drill State options
   Specifies the desired drill state:
   Measure options  |
   Specifies either one of the following options:
   Split:  |
   Check Each distinct value of the first key makes a separate file or table to split the summary export according to each value change in the first key (i.e., the leftmost one). If you choose this option, specify the desired Automatic Naming setting, either "by files" to have each distinct value of the first key make a separate file, or "by tables" to have each change of it make a separate table.  |
   Select Filter
   Applies filters to the summary. Select the "All filters" option to apply all of the available filters or the "No filter" option to apply none of them. If you choose the "All filters" option, specify the desired Automatic Naming setting, either "by files" or "by tables".  |
   Sort Order  |
   Applies a sort to the summary.  |
Excel Output
The Excel Output panel displays if your export outputs to an Excel file.
Excel output
   Field  |
   Description  |
   File Name  |
   Allows you to browse for a location to save the file and also to select the file type.  |
   Table Name  |
   Displays the current name of the table. You can assign a new table name here.  |
   Existing Tables  |
   Displays the names of the tables in the file when exporting to a file that already exists.  |
   When output files exist options  |
   Provides options for when a file of the specified name and type already exists in the export location. Select one of the following options:
EXCEL ADVANCED PROPERTIES
   Field  |
   Description  |
   Digital Signature  |
   This option is available for Table and Summary exports and allows you to embed the currently selected digital signature to the exported Excel file (XLSX/XLSM). By adding a digital signature, you establish the authenticity, integrity, and non repudiation of the export output.  |
   Certificate...  |
   Select this button to display a Select Certificate dialog. Options will allow you to digitally sign with a valid X.509 Certificate (an existing Certificate selected from the Current User's Certificate Store or from a Certificate file).  |
   Filter: Add AutoFilter drop down lists to column labels in the Table  |
   This option enables the Excel AutoFilter feature, ready and active when you open the exported Excel file. Note: Monarch Complete does not apply an AutoFilter when it adds data to an existing worksheet. Overwriting an existing sheet falls into this category. In this case it preserves the worksheet (since there may well be hidden data, macros, etc, associated with the worksheet) and overwrites the old named range data with new named range data. Since two AutoFilters cannot exist on the same worksheet, Monarch Complete makes no assumptions regarding an existing AutoFilter and does not apply one.  |
   Include Pivot Table sheet  |
   This option is available for Table exports to Excel 2007 (XLSX) files.  |
   Fields Tab  |
   Use this tab to select the desired pivot field(s)  |
   Options  |
   Use this tab to select the pivot options (see Pivot Table Tab Options below)  |
Pivot Table
Use this tab to specify pivot table options when performing a table export to an Excel 2007 (xlsx, xlsm) file.
   Field  |
   Description  |
   Name  |
   By default, the Pivot Table is named “PivotTable”. You can assign a new name to it by entering it here..  |
   Weight  |
   This refers to the Pivot Table style weight that will be applied when the Pivot Table is rendered in Excel. There are 3 options: Light, Medium and Dark. The weight is used in conjunction with the style index.  |
   Index  |
   This is the number of the table format style that will be applied when the Pivot Table is rendered in Excel. Excel has 28 styles available in 3 weights. This style can be viewed in Excel by selecting the “Format as Table” menu item when viewing a Pivot Table.  |
   Apply to row headers  |
   Applies the style settings to the row headers of the Pivot Table.  |
   Apply to column headers  |
   Applies the style settings to the column headers of the Pivot Table.  |
   Banded rows  |
   Applies alternate color shading to the rows in the Pivot Table.  |
   Banded columns  |
   Applies alternate color shading to the columns in the Pivot Table.  |
   Show grand totals for rows  |
   Displays grand totals for each row of the Pivot Table.  |
   Show grand totals for columns  |
   Displays grand totals for each column of the Pivot Table.  |
PDF Output
The PDF Output panel displays if your export outputs to a PDF file.
   Field  |
   Description  |
   Description  |
   Displays a description of what the export will do when run, as well as the name and path of the export file.  |
   Open Password  |
   Password-protects the PDF file.  |
   Apply  |
   Allows you to password protect the PDF file. Select this option and then click the adjacent Change Open Password button.  |
   Change Open Password  |
   Displays the Change Password dialog. Use this dialog to specify the password that must be supplied to open the PDF file.  |
   Permissions options  |
   Allows you to restrict the permissions available to users of the PDF file. Note: If you choose not to specify PDF file permissions, users will have full access to it.  |
   Apply  |
   Specifies permissions for the PDF file.  |
   Printing allowed  |
   Allows the PDF file to be printed.  |
   Content extraction allowed  |
   Allows copying (e.g., cut and paste) of the PDF file's content.  |
   Editing allowed  |
   Allows editing of the PDF file.  |
   Annotation (comments) allowed  |
   Allows comments to be added to the PDF file.  |
   Change Permission Password  |
   Displays the Change Password dialog. Use this dialog to specify the password that must be supplied to change the PDF file permissions.  |
   Encryption  |
   Encrypts the file through either of the following options. One (or both) of the passwords must be applied to enable encryption.
   ANSI Locale  |
   Select the appropriate locale for ANSI Encoding. You can select to use:
Table Output
The Table Output panel displays if your export outputs to a database table.
   Field  |
   Description  |
   Table Name  |
   Displays the current name of the table. You can assign a new table name by entering it here.  |
   Existing Tables  |
   When output tables exist options  |
   Tells Monarch Complete what to do if the output table already exists. These options are only accessible if you select a table from the Existing Tables list.
