Change Password Dialog
When configuring an export to a PDF file, use this dialog to specify the password that must be supplied to open the file or to change the permissions for it.
options
       Field  |
       Description  |
       Enter password  |
       Enter the password you want to assign to the PDF file.  |
       Confirm  |
       Confirm the password by entering it again.  |
       Save password as PDF export default  |
       Select if you want to use the specified password as the default password for all exported PDF files.  |
       OK  |
       Click to save changes you have made to the settings and close the dialog.  |
       Cancel  |
       Close the dialog without saving changes.  |
       Help  |
       Display this help topic.  |
