Select Certificate Dialog
Use this dialog to select or change the Certificate to be used when exporting to Excel 2007 or later (.xlsx/.xlsm) from a Table or Summary view. This dialog displays when you click the Certificate... button on the Excel Advanced Features screen of the Export wizard (in Monarch Classic) or select a certificate location (in Monarch Data Prep Studio).
options
Field |
Description |
Change to Certificate from Store. |
Select this button to display a list if Certificates currently available on your Certificate Store. Select a Certificate from the list and click OK. |
Change to Certificate from File. |
Select this list to display the standard File Open window. Navigate to the folder containing your Certificate and then select it. You will be asked to enter the Certificate Password before the Certificate can be selected. |
