HyperCrash
PamStamp Format
PamStamp Format
Previous topic Next topic Expand/collapse all hidden text
PamStamp Format
Card 1: File type identifier
1
2
3
4
5
6
7
8
9
AMAP
Where:
Unit
•AMAP
is a keyword
Keyword
No
Card 2 and 3: Control information
1
2
3
4
5
6
7
8
9
Nb_ci
Nb_Nodes
Where:
Unit
•Nb_ci
is the number of control information which is presently equal to 6
Integer
No
•Nb_Nodes
is the number of nodes in the model
Integer
No
Card 4: Nodes (one card per node)
1
2
3
4
5
6
7
8
9
NODE /
Node_id
x_coord
y_coord
z_coord
Where:
Unit
•NODE /
is a keyword
Keyword
No
•Node_id
is the identifier of the node
Integer
No
•i_coord
is the i coordinate value of the node in the global frame
Real
Length
Card 5: 4 nodes and 3 nodes shell elements (one card per element)
1
2
3
4
5
6
7
8
9
SHELL /
Elem_id
Node_1
Node_2
Node_3
Node_4
NPT
NPS
Where:
Unit
•SHELL /
is a keyword
Keyword
No
•Elem_id
Integer
No
•Node_i
is the node identifier number of the shell connectivity
Integer
No
•NPT
is the number of integration point through the thickness
Integer
No
•NPS
is the number of Gauss points on the shell surface (not currently used)
Integer
No
Card 6: Shell variables description (one card per variable)
1
2
3
4
5
6
7
8
9
Var_key
Nb_values
NPT_dpd
NPS_dpd
Where:
Unit
•Var_key
is the variable type keyword. THIC, PLAS and STRS keywords are taken into account (other keywords are ignored).
Integer
No
•Nb_values
is the number of values to be read for this variable
Integer
No
•NPT_dpd
is a flag for the dependency on the number of integration points through the thickness and which can be:
•0: independent
•1: dependent
Integer
No
•NPS_dpd
is a flag for the dependency on the number of Gauss points (not used today) and which can be:
•0: independent
•1: dependent
Integer
No
Card 7: Shell variables data block description (One card per variable)
1*
2*
3*
4*
5*
6*
Var_1(1,1,1)
Var_1(2,1,1)
Var_1(Nb_values,1,1)
Var_1(1,2,1)
Var_1(Nb_values,NPT,1)
Var_2(1,1,1)
Var_Nv(Nb_values,NPT,1)
Var_Ns(1,1,1)
*field of 13 digits.
Where:
Unit
•Var_i
is a specific variable type (thickness, plastic strain …)
Real
Length, Force/length2 or no unit
•Nb_values
is the number of values per variable
Integer
No
•NPT
Integer
No
•Nv
is the number of variables
Integer
No
•Ns
is the number of 3 nodes and 4 nodes shell elements
Integer
No
hmtoggle_plus1Example
AMAP
      6
                          10528
NODE  /     9276   .71720192E+02  -.44168634E+03  -.11976915E+02
NODE  /     9277   .73868263E+02  -.44167099E+03  -.98283386E+01
NODE  /     9278   .75555687E+02  -.44165979E+03  -.73018613E+01
NODE  /     9279   .76718987E+02  -.44165094E+03  -.44946604E+01
SHELL /     9025            9025    9057    9058    9026       3       1
SHELL /     9026            9026    9058    9059    9027       3       1
SHELL /     9027            9027    9059    9060    9028       3       1
SHELL /     9028            9028    9060    9061    9029       3       1
THIC        6
      1       0       1       1       0       0
PLAS        6
      1       1       1       0       0       0
STRS        6
      5       1       1      -1       1      -2
 .100002E+01  .000000E+00  .000000E+00  .000000E+00 -.191125E-03 -.685494E-05
 .543749E-04  .000000E+00  .000000E+00 -.220166E-03 -.492977E-04  .334407E-04
 .000000E+00  .000000E+00 -.249215E-03 -.914052E-04  .124898E-04  .000000E+00
 .000000E+00
 .100004E+01  .000000E+00  .000000E+00  .000000E+00  .194877E-03  .105157E-03
-.277142E-04  .000000E+00  .000000E+00  .208800E-03  .895069E-04 -.716815E-04
 .000000E+00  .000000E+00  .222600E-03  .736836E-04 -.115605E-03  .000000E+00
 .000000E+00
 .100003E+01  .000000E+00  .000000E+00  .000000E+00 -.163653E-03 -.141608E-03
 .168436E-03  .000000E+00  .000000E+00 -.175705E-03 -.141802E-03  .103958E-03
 .000000E+00  .000000E+00 -.187603E-03 -.141966E-03  .394956E-04  .000000E+00
 .000000E+00
 .100006E+01  .000000E+00  .000000E+00  .000000E+00  .137944E-03  .227799E-03
-.359828E-04  .000000E+00  .000000E+00  .125826E-03  .198729E-03 -.117759E-03
 .000000E+00  .000000E+00  .113734E-03  .169621E-03 -.199548E-03  .000000E+00
 .000000E+00
