HyperCrash
Fast Form 3D Format
Fast Form 3D Format
Previous topic Next topic Expand/collapse all hidden text
Fast Form 3D Format
Results Mapper is able to read the user format defined as follows:
Card 1: header (optional)
1
2
3
4
5
6
7
8
9
10
BEGIN BULK
Where:
Unit
•BEGIN BULK
is a keyword to define the beginning of the data
Keyword
No
Card 2: Nodes
1
2
3
4
5
6
7
8
9
10
GRID*
Node_id
x_coord
y_coord
cflag
cflag
z_coord
Where:
Unit
•GRID*
is the keyword (double field format)
Keyword
No
•Node_id
is the identifier number of the node
Integer
No
•I_coord
are the coordinate values of the node in the global frame
Integer
No
•cflag
is the continuation line flag
String
No
Card 3: 4 nodes shell elements
1
2
3
4
5
6
7
8
9
10
CQUAD4
EID
PID
Node_1
Node_2
Node_3
Node_4
cflag
cflag
TH_1
TH_2
TH_3
TH_4
Where:
Unit
•CQUAD4
is the keyword for the 4 nodes shell element
Keyword
No
•EID
is the identifier number of the element
Integer
No
•PID
is the property identifier number of the element
Integer
No
•Node_i
are the identifier numbers of the node connectivity of the shell
Integer
No
•cflag
String
No
•TH_i
is the thickness of the node_i
Real
Length
Card 4: 3 nodes shell elements
1
2
3
4
5
6
7
8
9
10
CTRIA3
EID
PID
Node_1
Node_2
Node_3
cflag
cflag
TH_1
TH_2
TH_3
Where:
Unit
•CTRIA3
is the keyword for the 3 nodes shell element
Keyword
No
•EID
Integer
No
•PID
Integer
No
•Node_i
Integer
No
•cflag
String
No
•TH_i
Real
Length
hmtoggle_plus1Example
BEGIN BULK
GRID*                  1                  -8.6314740e+02  -5.3617853e+02 1000001
*1000001   2.0918124e+02
GRID*                  2                  -8.6434418e+02  -5.3400195e+02 1000002
*1000002   2.0917842e+02
GRID*                  3                  -8.6554608e+02  -5.3181616e+02 1000003
*1000003   2.0917554e+02
GRID*                  4                  -8.6674969e+02  -5.2962726e+02 1000004
*1000004   2.0917262e+02
CQUAD4         1       4    2397     181     149    23980.0000000.000000+E100001
+E100001                1.5586081.5552421.5613061.560449
CQUAD4         2       4    2398     149     150    23990.0000000.000000+E100002
+E100002                1.5604491.5613061.5553691.560354
CQUAD4         3       4    2400     151     152    24010.0000000.000000+E100003
+E100003                1.5492411.5470191.5443201.554353
CTRIA3        83       4    2480    2479      63                        +E100083
+E100083                1.3716001.3562011.357757
CQUAD4        84       4    2401     152     153    24020.0000000.000000+E100004
+E100004                1.5543531.5443201.5341601.559306
