HyperCrash
Results Mapper Format
Previous topic Next topic Expand/collapse all hidden text
This specific format of Results Mapper information file is defined in order to import stamping results in the crash model.
Card 1: Title
/TITLE
1
2
3
4
5
6
7
8
9
10
Title-name
Where:
Unit
•TITLE
Is a keyword
Keyword
No
•Title-name
Is the a name of the model
String
No
Card 2: Results type
/MAPPED_DATA
1
2
3
4
5
6
7
8
9
10
Flag
Where:
Unit
•MAPPED_DATA
Is a keyword
Keyword
No
•Flag
is a flag which can be:
•0: default
•1: for already projected results which come from AUTOFORM
Flag
No
Card 3: Nodes
/NODE
1
2
3
4
5
6
7
8
9
10
Node_id
X_coord
Y_coord
Z_coord
Where:
Unit
•NODE
Is a keyword
Keyword
No
•Node_id
Is the node identifier number
Integer
No
•X_coord
is the coordinate value of the node around first global frame direction
Real
Length
•Y_coord
is the coordinate value of the node around second global frame direction
Real
Length
•Z_coord
is the coordinate value of the node around third global frame direction
Real
Length
Card 4: 4 nodes shell elements
/ELEM/ELEM_TYPE
1
2
3
4
5
6
7
8
9
10
Elem_id
Node_1
Node_2
Node_3
Node_4
Where:
Unit
•ELEM
is a keyword
Keyword
No
•ELEM_TYPE
is a keyword which define the type of element:
•SHELL4N for the 4 node shell element
•SHELL3N for the 3 node shell element
Keyword
No
•Elem_id
is the element identifier number
Integer
No
•Node_i
is node identifier number of the element connectivity
Integer
No
Card 5: Stamping results
/XCHANGE_DATA/LOCAL_FRAME
1
2
3
4
5
6
7
8
9
10
Elem_id
NPT
NPS
Where:
Unit
•XCHANGE_DATA
is a keyword
Keyword
No
•LOCAL_FRAME
is a keyword. The results are written in the same local frame as the RADIOSS one.
Keyword
No
•Elem_id
Integer
No
•NPT
is the number of integration point through the thickness
Integer
No
•NPS
is the number of Gauss point on the shell surface (not currently used)
Integer
No
Card 6: Stamping results
1*
2*
3*
4*
5*
6*
Thick
S_X(1,1)
S_Y(1,1)
S_XY(1,1)
S_XZ(1,1)
S_YZ(1,1)
EPSP(1,1)
S_X(NPT,1)
S_Y(NPT,1)
S_XY(NPT,1)
S_XZ(NPT,1)
S_YZ(NPT,1)
EPSP(NPT,1)
* field of 12 digits.
Where:
Unit
•Thick
is the thickness of the element
Real
Length
•S_X(I,j)
is the stress around X direction for the ith integration point of the jth Gauss point of the element
Real
Force/length2
•S_Y(I,j)
is the stress around Y direction for the ith integration point of the jth Gauss point of the element
Real
Force/length2
•S_XY(i,j)
is the shear stress in the plane XY for the ith integration point of the jth Gauss point of the element
Real
Force/length2
•S_XZ(i,j)
is the shear stress in the plane XZ for the ith integration point of the jth Gauss point of the element
Real
Force/length2
•S_YZ(i,j)
is the shear stress in the plane YZ for the ith integration point of the jth Gauss point of the element
Real
Force/length2
•EPSP(i,j)
is the plastic stain in the element for the ith integration point of the jth Gauss point of the element
Real
Force/length2
Note:The 3 nodes shell elements must be written after the 4 nodes shell elements.
Card 7:
/ENDDATA
Where:
Unit
•ENDDATA
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
#XCHANGE INPUT FILE : Model.stp
/TITLE
example of M-Xhange file
/MAPPED_DATA
      0
/NODE
1 1.398435600E+02 3.913563370E+01-1.180800000E+01
1 1.868243430E+02 3.913563370E-01-1.180800000E+01
/ELEM/SHELL4N
1    7496    7498    7500    7501
2    7495    7499    7512    7514
/ELEM/SHELL3N/
1    7496    7498    7500
10        5676    7526    5644
/XCHANGE_DATA/GLOBAL_FRAME
#SHELL4N DATA
      1       1       1
2.09509E+00
1.29725E+02 1.29725E+02 7.37888E+02 1.78872E+02-2.67278E+02-1.44972E+02
9.34029E-04
      2       1       1
2.09509E+00
9.34029E-04
#SHELL3N DATA
      1       1       1
2.09509E+00
9.34029E-04
     10       1       1
2.09509E+00
9.34029E-04
/ENDDATA
