HyperCrash
LS-DYNA Format
LS-DYNA Format
Previous topic This is the last topic Expand/collapse all hidden text
LS-DYNA Format
Previous topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Results Mapper is able to read the user format as defined following:
Card 1: Nodes
*NODE
1
2
3
4
5
6
7
8
9
10
id
X_coord
Y_coord
Z_coord
Where:
Unit
•*NODE
is the keyword
Keyword
No
•id
is the identifier number of the node
Integer
No
•I_coord
are the coordinate values of the node in the global frame
Real
No
Card 2: 4 nodes shell elements
*ELEMENT_SHELL_THICKNESS
1
2
3
4
5
6
7
8
9
10
EID
PID
Node_1
Node_2
Node_3
Node_4
TH_1
TH_2
TH_3
TH_4
Where:
Unit
•*ELEMENT_SHELL_THICKNESS
is a keyword
Keyword
No
•EID
is the identifier number of the element
Integer
No
•PID
is the part identifier number of the element
Integer
No
•Node_i
are the identifier numbers of the node connectivity of the shell
Integer
No
•TH_i
is the thickness of the node_i
Real
Length
Card 3: Initial stress and strain
*INITIAL_STRESS_SHELL
1
2
3
4
5
6
7
8
EID
NPLANE
NTHICK
T
SIGXX
SIGYY
SIGZZ
SIGXY
SIGYZ
SIGZX
EPS
Where:
Unit
•*INITIAL_STRESS_SHELL
is a keyword
Keyword
No
•EID
Integer
No
•NPLANE
Integer
No
•NTHICK
Integer
No
For each NTHICK and NPLANE:
Where:
Unit
•T
is the parametric coordinate of through thickness integration point
Real
No
•SIGij
are the tensor stress values
Real
Pressure
•EPS
is the effective plastic strain
Real
No
hmtoggle_plus1Example
*NODE
$   NODE               X               Y               Z      TC      RC
  19891 -0.10000000E-04  0.60475000E+03 -0.34046400E+03       1       0
  19892 -0.40078700E+02  0.60280680E+03 -0.34044900E+03       0       0
  19893 -0.80098000E+02  0.59983900E+03 -0.34043500E+03       0       0
  19894 -0.11991700E+03  0.59482330E+03 -0.34042300E+03       0       0
  19895 -0.15930000E+03  0.58709760E+03 -0.34041400E+03       0       0
$    EID     PID      N1      N2      N3      N4
$     T1      T2      T3      T4
  19519   65871   20698   20219   19918   20221
   0.100753E+01    0.100425E+01    0.961544E+00    0.974212E+00
  19520   65871   20220   19917   20219   20698
   0.104208E+01    0.104628E+01    0.100425E+01    0.100753E+01
  19521   65871   19948   20220   20698   20224
   0.103773E+01    0.104208E+01    0.100753E+01    0.101316E+01
$      EID    NPLANE    NTHICK
$        T     SIGXX     SIGYY     SIGZZ     SIGXY     SIGYZ     SIGZX       EPS
    19519         4         5
-0.906E+00 0.195E+03-0.214E+03 0.429E-01-0.263E+02 0.108E+01 0.323E+01 0.179E+00
-0.906E+00 0.294E+03-0.969E+02 0.127E+00-0.603E+02-0.542E+00 0.621E+01 0.227E+00
-0.906E+00 0.346E+03-0.297E+01 0.955E-01-0.346E+02-0.509E+00 0.577E+01 0.167E+00
-0.906E+00 0.396E+03 0.800E+02 0.188E+00-0.629E+02-0.206E+01 0.847E+01 0.239E+00
-0.538E+00 0.213E+03-0.197E+03 0.375E-01-0.256E+02 0.103E+01 0.318E+01 0.182E+00
-0.538E+00 0.307E+03-0.839E+02 0.112E+00-0.594E+02-0.507E+00 0.598E+01 0.231E+00
-0.538E+00 0.359E+03 0.109E+02 0.821E-01-0.334E+02-0.584E+00 0.540E+01 0.173E+00
-0.538E+00 0.405E+03 0.891E+02 0.166E+00-0.616E+02-0.203E+01 0.799E+01 0.246E+00
0.000E+00 0.239E+03-0.174E+03 0.287E-01-0.247E+02 0.951E+00 0.300E+01 0.188E+00
0.000E+00 0.326E+03-0.656E+02 0.911E-01-0.579E+02-0.463E+00 0.556E+01 0.239E+00
0.000E+00 0.377E+03 0.298E+02 0.637E-01-0.317E+02-0.691E+00 0.478E+01 0.182E+00
0.000E+00 0.418E+03 0.102E+03 0.135E+00-0.597E+02-0.200E+01 0.723E+01 0.255E+00
0.538E+00 0.263E+03-0.151E+03 0.196E-01-0.238E+02 0.868E+00 0.270E+01 0.194E+00
0.538E+00 0.344E+03-0.482E+02 0.711E-01-0.565E+02-0.426E+00 0.504E+01 0.247E+00
0.538E+00 0.392E+03 0.474E+02 0.476E-01-0.300E+02-0.794E+00 0.408E+01 0.191E+00
0.538E+00 0.431E+03 0.114E+03 0.107E+00-0.580E+02-0.196E+01 0.642E+01 0.265E+00
0.906E+00 0.279E+03-0.136E+03 0.137E-01-0.231E+02 0.809E+00 0.242E+01 0.198E+00
0.906E+00 0.355E+03-0.367E+02 0.584E-01-0.555E+02-0.404E+00 0.464E+01 0.252E+00
0.906E+00 0.402E+03 0.585E+02 0.381E-01-0.290E+02-0.862E+00 0.356E+01 0.198E+00
0.906E+00 0.438E+03 0.122E+03 0.901E-01-0.568E+02-0.195E+01 0.583E+01 0.272E+00
    19520         4         5
-0.906E+00 0.185E+03-0.232E+03 0.260E-01-0.991E+01 0.154E+00 0.220E+01 0.180E+00
-0.906E+00 0.173E+03-0.243E+03 0.433E-01-0.307E+01 0.209E+00 0.274E+01 0.178E+00
-0.906E+00 0.161E+03-0.257E+03 0.182E-01-0.865E+01 0.108E+01 0.195E+01 0.186E+00
-0.906E+00 0.150E+03-0.267E+03 0.327E-01-0.200E+01 0.115E+01 0.238E+01 0.184E+00
-0.538E+00 0.184E+03-0.232E+03 0.260E-01-0.988E+01 0.154E+00 0.220E+01 0.180E+00
-0.538E+00 0.173E+03-0.243E+03 0.432E-01-0.303E+01 0.210E+00 0.274E+01 0.178E+00
-0.538E+00 0.161E+03-0.257E+03 0.181E-01-0.862E+01 0.108E+01 0.195E+01 0.186E+00
-0.538E+00 0.150E+03-0.267E+03 0.326E-01-0.196E+01 0.115E+01 0.238E+01 0.184E+00
