HyperCrash
M00 File Description
The M00 file is a file which contains the information which does not exist in the D00 (RADIOSS Block Format only).
The keywords described here are:
•DUMMY_POS
•BELT_GEN
Dummy
/DUMMY_POS/Id/Title
Where:
Unit
•DUMMY_POS
Is a keyword
Keyword
No
•Id
Is the identifier number of the dummy
Integer
No
•Title
Is the name of the dummy, name displayed in the Safety page.
String
No
Card 1: subset and node group
1
2
3
4
5
6
7
8
9
10
Subset
Grnod
Where:
Unit
•Subset
is the identifier number of a subset defined in the associated D00 file, and corresponding to the Dummy.
Integer
No
•Grnod
is the identifier number of a node group defined in the associated D00 file.
Integer
No
dummy1.zoom40
dummy2.zoom40
dummy3.zoom40
Card 2: H point position in the global skew frame
1
2
3
4
5
6
7
8
9
10
Hx
Hy
Hz
Card 3: Rotation of the dummy (in the global skew frame around the H point)
1
2
3
4
5
6
7
8
9
10
Rx
Ry
Rz
Card 4: car reference point setting
1
2
3
4
5
6
7
8
9
10
Side sill (point 1)
Hinge_x (point 2)
Hinge_z (point 2)
Card 5: car reference point setting
1
2
3
4
5
6
7
8
9
10
B-pillar (point 3)
Bracket (point 4)
Floor (point 5)
Card 6: dummy positioning / car reference points
1
2
3
4
5
6
7
8
9
10
A
B
C
D
Card 7: dummy positioning / car reference points
1
2
3
4
5
6
7
8
9
10
E
F
G
I
Card 8: left leg positioning
1
2
3
4
5
6
7
8
9
10
Left_alpha_x
Left_alpha_y
Left_alpha_z
Card 9: left leg positioning
1
2
3
4
5
6
7
8
9
10
Left_beta_x
Left_beta_y
Left_beta_z
Card 10: left leg positioning
1
2
3
4
5
6
7
8
9
10
Left_theta_x
Left_theta_y
Left_theta_z
Card 11: right leg positioning
1
2
3
4
5
6
7
8
9
10
Right_alpha_x
Right_alpha_y
Right_alpha_z
Card 12: right leg positioning
1
2
3
4
5
6
7
8
9
10
Right_beta_x
Right_beta_y
Right_beta_z
Card 13: right leg positioning
1
2
3
4
5
6
7
8
9
10
Right_theta_x
Right_theta_y
Right_theta_z
Card 14: left arm positioning
1
2
3
4
5
6
7
8
9
10
Left_phi_x
Left_phi_y
Left_phi_z
Card 15: left arm positioning
1
2
3
4
5
6
7
8
9
10
Left_omega_x
Left_omega_y
Left_omega_z
Card 16: left arm positioning
1
2
3
4
5
6
7
8
9
10
Left_gamma_x
Left_gamma_y
Left_gamma_z
Card 17: right arm positioning
1
2
3
4
5
6
7
8
9
10
Right_phi_x
Right_phi_y
Right_phi_z
Card 18: right arm positioning
1
2
3
4
5
6
7
8
9
10
Right_omega_x
Right_omega_y
Right_omega_z
Card 19: right arm positioning
1
2
3
4
5
6
7
8
9
10
Right_gamma_x
Right_gamma_y
Right_gamma_z
Card 20: Torso / neck angle
1
2
3
4
5
6
7
8
9
10
Kappa_x
Kappa_y
Kappa_z
Card 21: Torso / pelvis angle
1
2
3
4
5
6
7
8
9
10
Lambda_x
Lambda_y
Lambda_z
Card 22: Head / neck angle
1
2
3
4
5
6
7
8
9
10
Eta_x
Eta_y
Eta_z
Card 23 to 25: Global rotation matrix
1
2
3
4
5
6
7
8
9
10
Angle_11
Angle_12
Angle_13
Angle_21
Angle_22
Angle_23
Angle_31
Angle_32
Angle_33
Go to
Belt
