HyperCrash
Belt
Belt
Belt
/BELT_GEN/partid
Where:
Unit
•BELT_GEN
is a keyword
Keyword
No
•partid
is the identifier number of the part of the belt in the associated RADIOSS input deck file (D00)
Integer
No
Card 1: subset and node group
1
2
3
4
5
6
7
8
9
10
Nnode
Npart
Where:
Unit
•Nnode
is the number of nodes used to define the belt
Integer
No
•Npart
is the number of part of the dummy model used to define the dummy external surface
Integer
No
Card 2: node list
1
2
3
4
5
6
7
8
9
10
Node_1
Node_2
Node_10
Node_Nnode
Where:
Unit
•Node_i
is the identifier number of nodes used to define the belt
Integer
No
Card 3: Dummy part list
1
2
3
4
5
6
7
8
9
10
Part_1
Part_2
Part_10
Part_Npart
Where:
Unit
•Part_i
is the identifier number of part used to define the dummy external surface
Integer
No
Card 4: Node coordinates
1
2
3
4
5
6
7
8
9
10
x_1
y_1
z_1
x_Nnode
y_Nnode
z_Nnode
Where:
Unit
•x_i
is the coordinate values (in the global frame) of the Nnode nodes listed previously.
Integer
No
•y_I
Integer
No
•z_i
Integer
No
Card 5: Seat belt definition flags
1
2
3
4
5
6
7
8
9
10
Elem_type
Rbcreat
Fixp
Where:
Unit
•Elem_type
is a flag which define the type of element used for the seat belt:
•0: shell
•1: multi_strand
•2: truss
•3: spring
Flag
No
•Rbcreat
is a flag to create automatically the rigid body on the tops of the seat belt:
•0: not created
•1: created
Flag
No
•Fixp
is a flag to allow the displacement of the reference points according the gap value:
•0: displacement allowed
•1: displacement not allowed
Flag
No
Card 6: default parameters
1
2
3
4
5
6
7
8
9
10
Gap
Width
Where:
Unit
•Gap
is contact interface gap between the dummy and the seat belt
Real
Length
•Width
is the width of the seat belt
Real
Length
Card 7: Parameters
1
2
3
4
5
6
7
8
9
10
Nleng
Nwidth
Where:
Unit
•Nleng
is the number of element in the length of the seat belt
Integer
No
•Nwidth
is the number of element in the width of the seat belt
Integer
No
Card 8: Parameters
1
2
3
4
5
6
7
8
9
10
Part
Mat
Prop
Where:
Unit
•Part
is the identifier number of the seat belt part (same ID as the one defined in the keyword line)
Integer
No
•Mat
is the identifier number of the seat belt material
Integer
No
•Prop
is the identifier number of the seat belt property
Integer
No
Card 9: Rigid bodies master node (only if Rbcreat=1)
1
2
3
4
5
6
7
8
9
10
Master1
Master2
Where:
Unit
•Master1
is the identifier number of the master node of the first rigid body (defined only if the flag, Rbcreat = 1)
Integer
No
•Master2
is the identifier number of the master node of the second rigid body (defined only if the flag, Rbcreat = 1)
Integer
No
Card 10: seat belt direction
1
2
3
4
5
6
7
8
9
10
V1x
V1y
V1z
V2x
V2y
V2z
Where:
Unit
•V1_i
is the component of the direction vector of the first top of the seat belt
Real
No
•V2_i
is the component of the direction vector of the second top of the seat belt
Real
No
