HyperCrash
Database Main Table
Database Main Table
Previous topic Next topic Expand/collapse all hidden text
Database Main Table
The file, $MCRASHDIR/dummng/database_main.tbl defines the path of the different databases:
Two types of database may be defined:
•Private database: just for the user
•Public database: for any user
Card 1:
This card defines the type of database and their path:
/DUMMNG/DATABASE/type
<full_path>database_name_table.tbl
Where:
Unit
•DUMMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•type
is a keyword which define the type of database :
•PRIVATE for the private database
•PUBLIC for the common database
Keyword
No
•database_name_table.tbl
is the file name (with the full path) of the database table list of each databases
String
No
Several database tables can be defined under this keyword line.
Card 2: end of file
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
/DUMMNG/DATABASE/PRIVATE
$HOME/private_database/private_dummy_database_1.tbl
/DUMMNG/DATABASE/PUBLIC
$MCRASHDIR/database/dummy_database1.tbl
$MCRASHDIR/database/dummy_database2.tbl
/END
Database table file
For each database, there is only one table file (.tbl). This file defines all the sub-models (B00 files) located in the database.
Card 1: Dummy database path
This card defines the database path:
/DUMMNG/DATABASE/DIRECTORY
directory_path
Where:
Unit
•DUMMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•DIRECTORY
is a keyword
Keyword
No
•directory_path
is the default directory path where the dummy model will be stored
String
No
Card 2: model description
/DUMMNG/IMPORT/ONLY_DATABASE/YES
Option to deactivate the page (D00) where the user can read a dummy model which is not set in the database.
Card 3: model description
/DUMMNG/DATABASE/MODEL
/path/File_name
1
2
3
4
5
6
7
8
9
10
Key_1
Key_2
Where:
Unit
•DUMMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•MODEL
is a keyword
Keyword
No
•File_name
is the file name of the dummy model defined with its full path and/or with the variable, $MCRASHDIR.
String
No
•Key_i
is the keyword list used to defined the model. The keywords are defined in the file, $MCRASHDIR/dummng/keyword.tbl
String
No
To write a keyword with more than eight characters, the character ’@’ will be set at the first position of the next field (See the section, Keyword).
Card 4: end of file
/END
Where:
Unit
•END
Keyword
No
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
$DUMMY_BASE
$DUMMY_BASE/H350R12BD00
HYBRID_I@II     50      RIGID
/END
Dummy database environment
The dummy database will be defined with the variable, DUMMY_BASE.
Go to
Environment File Description
