HyperCrash
Dummy Manager
Dummy Manager
Previous topic Next topic Expand/collapse all hidden text
Dummy Manager
This section defines the necessary files used by the Safety menu.
Keyword
The model will be located in the database with a keyword list that will be used to research the model in the database.  All the keywords are defined in the file, $MCRASHDIR/dummng/keyword.tbl.
Each keyword list is defined inside a keyword group:
Card 1:
/DUMMNG/KEYWORD
keyword_group_name
1
2
3
4
5
6
7
8
9
10
Key_1
Key_2
Where:
Unit
•DUMMNG
is a keyword
Keyword
No
•KEYWORD
is a keyword
Keyword
No
•keyword_group_name
is the name of the keyword group
String
No
•Key_I
is the keyword list of the group of keyword (eight characters)
String
No
To write a keyword with more than eight characters, the character ’@’ will be set at the first position of the next field (See the keyword, HYBRID_III in the Example below).
Card 2: end of file
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/DUMMNG/KEYWORD
Norm
EUROSID USSID   HYBRID_I@II
/DUMMNG/KEYWORD
Person
ADULT   CHILD
/END
Go to
Environment File Description
