HyperCrash
Belt
Belt
Previous topic Next topic Expand/collapse all hidden text
Belt
The file, $MCRASHDIR/belt/geometrydef is used to set the default value of the belt geometry.
Card 1:
1
2
3
4
5
6
7
8
9
10
Width
Where:
Unit
•Width
Is the default belt width value
Real
Length
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
# BELT GEOMETRY DEFINITION FILE
#  UNIT : mm
#          Width             gap  nbelw nblength
           50.              4.0       3      30
# END OF BELT GEOMETRY DEFINITION FILE
Go to
Environment File Description
