HyperCrash
Default Material and Property Setting
Previous topic Next topic Expand/collapse all hidden text
The file default_mat_prop.txt is located inside the directory $MCRASHDIR/defaults.  This file contains the default material and/or properties which will be used during the file input.
Card 1: File setting
/INPUT/input_file_type/input_type
1
2
3
4
5
6
7
8
9
10
<full path> file_name
Where:
Unit
•INPUT
is a keyword
Keyword
No
•input_file_type
is the type of file which can be:
•NASTRAN
•UNV
•ANSYS
•HYPERCRASH
Keyword
No
•input_type
is the type of input which can be:
•PROP
•MAT
Keyword
No
•file_name
is the file name which contains all the defaults properties and material of the file input type
String
No
Card 2:
This card defined the beginning and the end of the default definition of the material and property for the defined input file type.
/input_file_type/state
Where:
Unit
•input_file_type
is a keyword
Keyword
No
•state
is a keyword:
•BEGIN
•END
Keyword
No
Card 3:
Between the card BEGIN and END, the property and the material linked to each type of element can be defined as follows:
/element_type/input_type/input_type_id
Where:
Unit
•element_type
•PART_QUAD
•PART_SHELL
•PART_SOLID
•PART_TETRA
•PART_TETRA10
•PART_XELEM
•PART_BEAM
•PART_TRUSS
•PART_SPRING
•PART_RIVET
•PART_BRIC20
•PART_SHEL16
•PART_SPH
Keyword
No
•input_type
•PROP
•MAT
Keyword
No
•input_type_id
is the identifier of the property or material card.
Integer
No
hmtoggle_plus1Example
File: default_mat_prop.txt
/INPUT/NASTRAN/PROP
$MCRASHDIR/defaults/nastran.def
/INPUT/NASTRAN/MAT
/NASTRAN/BEGIN
/PART_SHELL/PROP/1
/PART_SHELL/MAT/3
/PART_SOLID/PROP/2
/PART_SOLID/MAT/3
/NASTRAN/END
File: propD00
#RADIOSS STARTER      41
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/PROP/TYPE1/1/DEFAULT SHELL
#-Ishel| Ismstr|
      0       0
#-     hm      |       hf      |       hr      |       dm      |
              0               0               0               0
#-  N  |Istrain|      Thick    |      Ashear   |       | Ithick|  Iplas|
      5       0             0.7               0               2       0
/PROP/TYPE14/25/DEFAULT SOLID
#-Isoli| Ismstr|
      1       2
#-     q_a     |      q_b      |       h       |
            1.1            0.05             0.1
/PROP/TYPE3/234/DEFAULT_BEAM
#-     | Ismstr|
              0
#-     dm      |       df      |
              0               0
#-    Area     |      Iyy      |      Izz      |      Ixx      |
            314             796             796            1592
#- Rot | Ishear|
000 000       0
/END
File: matD00
#RADIOSS STARTER      41
/MAT/LAW2/1/DEFAULT_STEEL_MATERIAL
#    Init. dens.      Ref. dens.
#-    Rho_i    |     Rho_0     |
        1.2e-09               0
#-     E       |      Nu       |
           2800             0.3
#-    a/C0     |      b/C5     |      n        |      Eps_max  |   sigma_max   |
            192             200            0.32               0               0
#-     c/C1    |     Eps_0     |  Icc  |
              0               0       0
#-     m/C3    |     T_melt/C4 |     rhoCp     |     T_i       |
              0               0               0               0
/MAT/LAW1/234/DEFAULT_ELASTIC_MATERIAL
#-    Rho_i    |     Rho_0     |
       7.89e-09               0
#-     E       |      Nu       |
         210000             0.3
/END
Go to
Main Module Environment File Description
