HyperCrash
Include List
Include List
Previous topic Next topic Expand/collapse all hidden text
Include List
To set this option add the file, $MCRASHDIR/includes/include_list with the parameter defined as follows.
To unset this option, remove (or rename) the file, $MCRASHDIR/includes/include_list or set the character, # can be set on the top of the line on the parameters you do not want to see.
The file, $MCRASHDIR/includes/include_list contains a list of RADIOSS data type that can be searched in a database include file at the writing of the D00.  After each type of data, there is the path of the data base file to search.
Note:Currently, only material is available.
Card 1:
/ENTITY
1
2
3
4
5
6
7
8
9
10
<full path> file_name
Where:
Unit
•ENTITY
Is a keyword which can be:
•MATERIAL
Keyword
No
•file_name
is the file name (with its full path) of the stored include file.
String
No
hmtoggle_plus1Example
/MATERIAL
/usr/people/project1/mat_file
If you select to ”include a data base material file", the following line is written in the RADIOSS input deck (D00 file):
#include/usr/people/project1/mat_file
and no material cards will be written in the RADIOSS input deck (D00 file).
Go to
Main Module Environment File Description
