HyperCrash
General Connection
General Connection
Previous topic Next topic Expand/collapse all hidden text
General Connection
The general connection will replace the spotweld definition file presented previously.
* Options not yet available are in light gray.
Logical connection definition
Logical connection defined by a link between a set of parts with several connections. The logical connection will contain the following information:
•part IDs*
•connection type
•connection ID(s)
* In the case of self-connection inside one part, the part ID will be defined twice.
Connection definition
A connection is an entity that contains a geometrical definition and the associated FEM model.
•type
•geometrical position
•geometrical definition
•FEM description
hmtoggle_plus1Example
Logical connection        1
Part_1, Part2, Part3
                 Spotweld
                 1        2        4        5        9        10
Spotweld                1
spotweld
                 Xcoordinate        Ycoordinate        Zcoordinate
                 spring id
                 interface id        node id        element id
Default connection file name
The default file, connection.def will be used to define for each connection type the definition file of the connection which has to be used:
$MCRASHDIR/connection/connection.def
In this file we will find for each connection both lines:
/TYPE/connection_type
1
2
3
4
5
6
7
8
9
10
<full path>PID_file
Where:
Unit
•Type
Is a keyword
Keyword
No
•connection_type
Is a keyword:
•SPOTWELD
•GLUE
•HEMMING
•WELDING LINE
Keyword
No
The end of the file will be specified with the keyword line:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
#--1---|---2---|---3---|---4---|---5---|---6---|…
/TYPE/SPOTWELD
$MCRASHDIR/connection/Default_spotweld_radioss.mco
/TYPE/GLUE
$MCRASHDIR/connection/Default_glue_radioss.mco
/TYPE/BOLT
$MCRASHDIR/connection/Default_bolt_radioss.mco
/TYPE/HEMMING
$MCRASHDIR/connection/Default_hemming_radioss.mco
/TYPE/WELDLINE
$MCRASHDIR/connection/Default_welding_line_radioss.mco
/END
Connection definition file
The modeling of a connection will be defined in the file:
$MCRASHDIR/connection/connection_name.mco
This file will start with the first line of the RADIOSS input deck (D00 file) and the unit system used in the file:
#RADIOSS STARTER      41
/UNIT/LENGTH/mm
/UNIT/MASS/g
/UNIT/TIME/ms
The connection_name will be the name displayed in the different HyperCrash windows to identify the connection.
Connection type
The type of element for the connection could be:
Where:
Unit
•TYPE
is a keyword
Keyword
No
•connection_type
is a keyword:
•SPOTWELD
•GLUE
•HEMMING
•WELDING LINE
Keyword
No
Element type
/ELEMENT/Element_type
Where:
Unit
•ELEMENT
is a keyword
Keyword
No
•Element_type
is a keyword:
•SPR_BEAM
•PREDIT
•SPR_GENE
•BEAM
•SOLID
•SOL_ORTH
beam type spring (default)
Predit spring
general spring
beam
general solid
orthotropic solid
Keyword
No
Link type
The link of these elements to the parts will be defined with:
/LINK/Link_type/Option
Where:
Unit
•LINK
is a keyword
Keyword
No
•Link_type
is a keyword:
•L_TIED_INTERFACE (default)
•L_RBODY
•L_BEAM
•L_COMMON_NODE
Keyword
No
•Option
is a keyword:
•MIDDLE (only for L_TIED_INTERFACE)
•OUTSIDE (only for L_TIED_INTERFACE)
•NONE
Keyword
No
Property
The default property will be defined as:
/PROP/Type/Option
1
2
3
4
5
6
7
8
9
10
<full path>Property_file
Where:
Unit
•PROP
is a keyword
Keyword
No
•Type
is a keyword:
•FIXED: HyperCrash will use the property as it is defined
•UPDATED: HyperCrash will use the property as a base and modify it according to different parameters
Keyword
No
•Option
is a keyword:
•COUPLE_OF_PART
•LOGICAL_CONNECTION (default)
•MODEL
Keyword
No
•Property_file
is the reference file name of the property defined with its full path and/or environment variable
String
No
Material
The default material will be defined like:
/MAT/Type/Option
1
2
3
4
5
6
7
8
9
10
<full path>Material_file
Where:
Unit
•MAT
is a keyword
Keyword
No
•Type
is a keyword:
•FIXED: HyperCrash will use the material as it is defined
•UPDATED: HyperCrash will use the material as a base and modify it according to different parameters
Keyword
No
•Option
is a keyword:
•COUPLE_OF_PART
•MODEL
Keyword
No
•Material_file
is the reference file name of the material defined with its full path and/or environment variable
String
No
Real approximation search
A tolerance parameter can be defined in order to compare a Real with an exact reference value +/- a percentage value.
/APPROXIM/STRICT_FLOAT/Percentage
Where:
Unit
•APPROXIM
is a keyword
Keyword
No
•STRICT_FLOAT
is a keyword
Keyword
No
•Percentage
defines the percentage value of the defined tolerance for the parameter /THICK/STRICT
Real
Caution:This option is available only for PREDIT spotweld type and for the parameter /THICK/STRICT.
/APPROXIM/STRICT_FLOAT/3
reference thickness –3% < part thickness < reference thickness +3%
Keywords will define which parameter of the material or the property will be modified and how it will be modified.
The parameters will be defined according the following variables:
THICKThickness of the part to link
YIELDYield stress of the material
YOUNGYoung modulus of the material
DENSDensity of the material
The effect of each variables will be taken into account according the following options:
MINthe minimum value of the parts to link
MEANthe average value of the part to link
MAXthe maximum value of the parts to link
STRICTthe exact value of the parts to link
The parameters will be:
Name
Element type
All the parameters of the property
Spring
Beam
Truss
DIAM_P
Diameter of the connection_type
Solid
Beam
Truss
FILE_P
The parameter is a file
All
PARAM_P
Parameter of parameter
All
Each variable will define the parameter according to a table, such as:
Variable
Parameter
Keyword line
The keyword line will be defined as:
/PARAM/param_id/support/param/p_index/p_option/variable/v_option
1
2
3
4
5
6
7
8
9
10
Variable_value
Parameter_value
Where:
Unit
•PARAM
is a keyword
Keyword
No
•param_id
is an identifier of the PARAM
Keyword
No
•support
defines where the parameter is applied:
•PROP_P
•MAT_P
Keyword
No
•param
is a keyword that defines the modified parameter of the support (PROP_P and MAT_P) and:
•DIAM_P
•FILE_P
•PARAM_P
Keyword
No
•p_index
is an index
•> 0 in case PARAM is an array
•= -1 in case PARAM is not an array
Integer
No
•p_option
is an option of the PARAM
•NONE
•ABS
•ORD
Keyword
No
•variable
is the variable keyword
•THICK
•YIELD
Keyword
No
•v_option
is an option of the variable
•MIN
•MEAN
•MAX
Keyword
No
The parameter is an integer
For each variable an Integer will define the correct parameter.
Keyword line
1
2
3
4
5
6
7
8
9
10
Variable_value
Param.
Where:
Unit
•Variable_value
is the variable value
Real
Depends on the variable
•Param.
is the corresponding parameter value
Integer
No
/PARAM/1/PROP_P/ISOLID/-1/NONE/THICK/MEAN
             0.50           1
             0.70           1
             0.90          12
             1.20          12
             2.00         112
The parameter is a Real
For each variable a Real will define the correct parameter.
Keyword line
1
2
3
4
5
6
7
8
9
10
Variable_value
Parameter_value
Where:
Unit
•Variable_value
Real
•Parameter_value
Is the corresponding parameter value
Real
No
/PARAM/1/PROP_P/DIAM_P/-1/NONE/THICK/MIN
             0.50               5.000
             0.70               6.000
             0.90               6.000
             1.20               7.000
             2.00               7.000
The parameter is a name
For the material, the variable is a name and HyperCrash will find the corresponding file in the database:
•$MCRASHDIR/mat if the parameter is MAT_P
•$MCRASHDIR/prop if the parameter is PROP_P
Keyword line
1
2
3
4
5
6
7
8
9
10
Variable_value
File_name
Where:
Unit
•Variable_value
Real
•File_name
is the corresponding file name
String
No
/PARAM/1/MAT_P/FILE_P/-1/NONE/YIELD/MEAN
            210.0        STEEL_1
            250.0        STEEL_2
            300.0        STEEL_3
            350.0        STEEL_4
            400.0        STEEL_5
The parameter is a function
For each variable, a basic function will be set in the property of the material definition file. This function will be scaled (in abscissa or ordinate) with the parameters.
Keyword line
1
2
3
4
5
6
7
8
9
10
Variable_value
Scale_value
Where:
Unit
•Variable_value
Real
•Scale_value
is the corresponding scale value
Real
No
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|…
/PARAM/1/PROP_P/TRA_FUNC1/0/ORD/THICK/MIN
             0.50              10000.00
             0.70              12000.00
             0.90              13000.00
             1.20              12000.00
             2.00              11000.00
/PARAM/2/PROP_P/TRA_FUNC1/0/ABS/THICK/MIN
             0.50                  3.00
             0.70                  3.00
             0.90                  2.00
             1.20                  1.00
             2.00                  0.90
Basic function defined in the default spring PID:
/FUNCT/1/Spotweld function FX
          -1.00                 -1.00
            -0.10                 -1.00
             0.00                  0.00
             0.10                  1.00
             1.00                  1.00
Function of the spotweld PID:
/FUNCT/95734/Spotweld function FX
            -2.00             -13000.00
            -0.20             -13000.00
             0.00                  0.00
             0.20             -13000.00
             2.00             -13000.00
The parameter option is PARAM
For each variable, an Integer will define the correct PARAM which has to be used.
Keyword line
1
2
3
4
5
6
7
8
9
10
Variable_value
Param_ID
Where:
Unit
•Variable_value
Real
•Param_ID
is the corresponding parameter identifier
Integer
No
/PARAM/12/PROP_P/PARAM_P/-1/NONE/YIELD/MIN
              150      13
              180      22
              200      33
Go to
Main Module Environment File Description
