HyperCrash
Bolt
Bolt
Previous topic Next topic Expand/collapse all hidden text
Bolt
The file, $MCRASHDIR/bolt/boltdef defines the bolt creation default values.
Card 1:
1
2
3
4
5
6
7
8
9
10
Version_number
Where:
Unit
•Version_number
is the file identifier
Text
No
It is strongly recommended to not modify this value.
Card 2:
1
2
3
4
5
6
7
8
9
10
Bolt_name
Where:
Unit
•Bolt_name
Is the default bolt name
Text
No
Card 3:
1
2
3
4
5
6
7
8
9
10
Property_name
Where:
Unit
•Property_name
is the default spring property file name
Text
No
Card 4:
1
2
3
4
5
6
7
8
9
10
Length1
Length2
Diameter1
Where:
Unit
•Length1
is the first cylinder’s length
Real
Length
•Length2
is the second cylinder’s length
Real
Length
•Diameter1
is the cylinder’s diameter
Real
Length
Card 5:
1
2
3
4
5
6
7
8
9
10
Spring_length
Where:
Unit
•Spring_length
is the length of the spring set in the bolt with spring.
Real
Length
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
# BOLT DEFINITION FILE
#  UNIT : s, N , mm, T (1t=1000kg)
# 1. GLOBAL DEFINITIONS:
#version number
V3.13_2.0
#default bolt name
New_Bolt
#default property name
SPRI_13_Bolt
#       length1|        length2|      diameter1|
            10.             10.             20.
# spring length|(1 mm)
             1.
# END OF BOLT DEFINITION FILE
Go to
Main Module Environment File Description
