HyperCrash
To move the upper limbs
1.Click the Upper limbs toggle to display the corresponding page.
2.In the Upper limbs positioning part of the window, select the left or right arm angle to adjust.
The part of the arm that will move is highlighted in red.
upper_limb
3.Use the mouse to move the arm:
4.Click manipulateDisplay-24.
5.In the graphic window, pick a node on the arm (the available nodes are displayed in green) and move the mouse to rotate the arm. The arm is moved along a red circle.
6.When finished, click Yes in the Dialog menu bar.
•If needed, pick another node to move the arm around the same angle, or click Cancel in the Dialog menu bar.
or
•Set the angle in the field.
or
•Click increaseDecrease to adjust the angle.
7.Click confirmGeneral-24 to save the angle setting.
8.If necessary, select another angle and repeat the same steps to adjust it.
9.Click Close to close the menu.
Go to
Dummy Positioner
