HyperCrash
To move the lower limbs
1.Click the Lower limbs toggle to display the corresponding page.
lower_limb
2.In the Lower limbs positioning part of the window, select the left or right leg angle to adjust:
3.The part of the leg that will move is highlighted in red.
4.Use the mouse to move the leg:
5.Click manipulateDisplay-24.
6.In the graphic window, pick a node on the leg (the available nodes are displayed in green) and move the mouse to rotate the leg. The leg is moved along a red circle.
7.When finished, click Yes in the Dialog menu bar.
•If necessary, pick another node to move the leg around the same angle, or click Cancel in the Dialog menu bar.
or
•Set the angle in the field.
or
•Click increaseDecrease to adjust the angle.
8.Click confirmGeneral-24 to save the angle setting.
9.If necessary, select another angle and repeat the same steps to adjust it.
10.Click Close to close the menu.
Go to
Dummy Positioner
