HyperCrash
To move the torso and the head
1.Click the Torso/Head to move the corresponding angles.
2.In the Torso/Head positioning part of the window, select the dummy angle to adjust.
The selected part is highlighted in red.
Torso
neck_thorax
Neck
thorax_pelvis
Head
head_neck
3.Use the mouse to move the selected part:
4.Click manipulateDisplay-24.
5.In the graphic window, pick a node on the selected part (the available nodes are displayed in green) and move the mouse to rotate it. The selected part is moved along a red circle.
6.When finished, click Yes in the Dialog menu bar.
•If necessary, pick another node to move again around the same angle, or click Cancel in the Dialog menu bar.
or
•Set the angle in the field.
or
•Click increaseDecrease to adjust the angle.
7.Click confirmGeneral-24 to save the angle setting.
8.If necessary, select another angle and repeat the same steps to adjust it.
9.Click Close to close the menu.
Go to
Dummy Positioner
