HyperCrash
To move the dummy to the right location
1.Merge a dummy in the model. (See Merge a dummy for more information.)
2.Select the desired dummy view. (See Dummy views for more information.)
Two options are available to set the dummy to the right location:
Use the car measurement value:
1.Click the Ref. points toggle to display the corresponding page.
2.Set the following information by filling in the fields or by clicking selectGeneralX-24 and selectGeneralZ-24 and picking a node, or by clicking increaseDecrease:
•Side sill Z coordinate.
•Seat hinge X and Z coordinates.
•B-Pillar X coordinate.
•Front seat bracket X coordinate.
•Floor Z coordinate.
3.Click the H point toggle to display the corresponding page.
4.Set the following information by filling in the fields or by clicking selectGeneralX-24 and selectGeneralZ-24 and picking a node, or by clicking increaseDecrease:
•A: distance Z from the sill.
•B: distance Z from the seat.
•C: distance X from the seat.
5.Click the Body toggle to display the corresponding page.
6.Set the following information by filling in the fields or by clicking increaseDecrease:
•D: distance X between the upper arm joint and the B pillar.
•E: distance X between the head accelerometer and the B pillar.
•F: distance X between the ankle joint and the front seat anchorage point.
•G: distance X between the ankle joints.
•I: distance X between the knee joints.
7.If necessary, manually adjust the different parts of the dummy. The different operations are defined.
8.In the Global dummy displacement portion of the window, set the following information by filling in the fields or by clicking selectGeneralX-24, selectGeneralY-24, and selectGeneralZ-24 and picking a node, or by clicking increaseDecrease:
•The Hx field: H point position in X direction.
•The Hy field: H point position in Y direction.
•The Hz field: H point position in Z direction.
•The Rx field: global rotation position around global X axis.
•The Ry field: global rotation position around global Y axis.
•The Rz field: global rotation position around global Z axis.
Go to
Dummy Positioner
