HyperCrash
To modify or delete a Gravity Load
1.From the Menu Bar, select LoadCase > Gravity Load > Modify.
2.Select gravity loads using one of the following methods:
Button
Behavior
treeSelectUnselectAll-24
select all the gravity loads
selectGeneral-24
pick the arrow of the gravity load in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectSpotweldByBox
select gravity loads by box (use the SHIFT key to use a polygon box).
selectPartGeneral-24
pick parts in the graphic window to select all the gravity loads applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all gravity loads applied to those parts.
Click the gravity load line in the listing window to select it. Several gravity loads from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
3.Select only one gravity load and click reviewGeneral-24 for the option to do any of the following:
•Change the gravity load name.
•Select or deselect nodes or parts (see Node selection).
•Modify the skew frame (see Reference axis).
•Modify the sensor (see Sensor).
•Modify the properties (see Properties setting).
•Modify the gravity load direction (see Direction setting).
4.Click deleteGeneral-24 to delete the selected gravity load.
5.Answer the question in the pop-up dialog window with Yes or Cancel.
6.Click Save to save the modified gravity load; or
Click Cancel to cancel the gravity load modification.
7.Click Close to close the menu.
Go to
Gravity
