HyperCrash
To create an Initial Velocity
1.From the Menu Bar, select LoadCase > Initial Velocity.
2.Right-click to access the context menu, then click Create New.
3.Enter a name in the Initial Velocity Creation field and validate with Ok.
4.In the Selection folder, select nodes using the different tools from the Selection folder.
5.In the Reference Axis folder:
•Click the Reference Axis folder.
•Define the Reference axis using the different tools from the Reference Axis folder.
6.Click moveNodeTrans to create an initial velocity in Translation.
7.Set the initial velocity components in the Vx, Vy and Vz translation component fields.
8.Click moveNodeRotate to create an initial velocity in Rotation.
9.Set the initial velocity components in the Rx, Ry and Rz rotation component fields.
10.Click Save to save the created initial velocity; or
Click Cancel to cancel the initial velocity creation.
11.Click Close to close the menu.
Go to
Initial Velocity
