HyperCrash
Bolt
Bolt
Bolt
A bolt links two sets of parts with:
•an undeformable connection. The two sets of parts are linked with one rigid body. (This option is called "rigid bolt".); or
•a deformable connection. One rigid body is created for each set of parts. Those two rigid bodies are linked with a spring type beam (type 13). This option is called "bolt with spring".
The slave nodes of the rigid body(ies) are searched in the cylinder defined below:
connection_02
All the nodes of the selected parts (set 1 and set 2) inside the cylinder will be added to the bolt.
connection_19
Rigid Bolt
connection_20
Bolt with spring
The parameters' default values are defined in the file, <install directory>/environment/.../bolt/boltdef. This file contains:
•the version number
•the default bolt's name
•the default property name
•L1 , L2 , D
•the spring length (1 mm)
How Do I ...
Create a bolt
Modify a bolt
Check a bolt
Delete a bolt
See also
Export Filet
Extract
Time History Setting
