HyperCrash
To extract spotwelds
The selected springs type beam (type 13) which have their two nodes linked to a shell element with tied interfaces (type 2) are translated into the selected Connection type.
This option is useful when a RADIOSS D00 model is read without a M00 file.
The Connection type can be:
•Spotweld
•Glue (only the connection between two plates will be extracted).
•Welding line
•Hemming (only the connection between two plates will be extracted).
There are three ways to do the spotweld extraction:
Extract from D00.
1.From the Menu Bar, select Connections > Spotweld > Extract from Model.
All the selected springs type beam (type 13) parts are translated.
Extract from tree selection.
1.In the Tree menu, select springs type beam (type 13) parts in the tree.
2.From the Menu Bar, select Connections, then <connection type>, and select Extract from Tree Selection.
Extract from browser selection.
2.From the Menu Bar, select Connections, then <connection type>, and select Extract from Browser Selection.
Only the selected springs type beam (type 13) parts in the tree are translated.
See also
Spotweld
Export File
