HyperCrash
Time History Setting
In the Modify page of the selected connection (Spotweld, Bolt, Glue, Welding line, or Hemming):
1.Select the connection to add to or remove from TH (time history) in the connection list.
2.In the connection list window, open the context menu (right-click of the mouse).
3.Select either:
•Put in TH to set the connection in TH
•Remove from TH to unset the connection in TH
In the connection list column accelerometersGeneral-24, the status of the connection can be:
•Yes
The connection is set in TH.
•Partially
The connection ID is partially set in TH (only some springs of the connection).
•No
The connection is not set in TH.
•None
The connection cannot be set in TH.
For each connection, the following elements are set in TH:
•Spotweld
Each spring of the spotweld connection.
•Bolt
The spring of the bolt for the deformable bolt;
The rigid body for the rigid bolt.
•Glue
The spring of the glue connection.
•Welding line
The spring of the welding line connection.
•Hemming
The spring of the hemming connection.
