Defining a Coaxial Cable Using Cable Characteristics
A coaxial cable can be characterised by its characteristic impedance and propagation constant.
On the Cables tab, in the
Definitions group, click the
Specified coax icon.
Under Cable definition, from the Definition
type
drop-down list, select Specify cable
characteristics.
Figure 1. The Create coaxial cable dialog (Specify cable characteristics). -
Under Characteristics, specify the following:
- In the Magnitude of characteristic imp. (Ohm) field, enter the characteristic impedance (magnitude) for the coaxial cable.
- In the Attenuation (dB/m) field, enter the attenuation of the coaxial cable in dB/m.
- In the Velocity of propagation (%) field, enter a percentage for the velocity of propagation through the coaxial cable.
Under Cable definition, in the Outer
radius field, enter the outer radius of the coaxial cable.
Note: If a braided shield is applied to the coaxial cable the outer radius should be between the stretching limits for a braided shield.
Under Shielding, from the Shield
drop-down list, select one of the following:
- To add an outer cable shield consisting of a predefined shield, select a cable shield.
- To add an outer cable shield consisting of a shield, which is not yet
defined in the model, click the
icon to define a new cable shield.
Under Insulation layer (coating), specify the
following:
- To add a coating, select the Apply
coating check box.
- From the Medium drop-down list, specify the coating medium.
- In the Thickness field, specify the coating thickness.
- To remove the coating, clear the Apply coating check box.
coating check box.
- In the Label field, add a unique label for the coaxial cable.
- Click Create to create the coaxial cable and to close the dialog.
