Upload Functional View
You can build your own Functional Views from an external Excel file. The uploaded Functional View creates a new Functional View from an external Excel file or updates the current Functional View by inserting the structure described in the external Excel file.
- Click .
Click the
icon.
In the Import Functional View dialog box, select one of
the following options:
- Update Current Functional View
- Create New Functional View
The Functional View that you upload will update the current Functional View by inserting the structure described in the external Excel file.
You can create a new Functional View from an external Excel file.
- Select the Create new Functional View tabbed page.
- Specify the name of Functional view to be created.
- Specify the Master Level which is the number of sub-levels that the Functional View must contain in the Max Level field.
- Click Upload to navigate to the file that you want to import into the node.
- Click Preview and then click
Confirm to create the new Functional View.
The content of the entire file is moved to the selected node of the Functional View.
