Frame System
The tasks that can be carried out in the Frame System options are:
- Add Item
- Delete Item
- Enable changes
- Save changes
- Undo changes
- Export data as XLSX Report
- Show/Reset Column filter
- Add item Frame number start, Frame number end Frame spacing and user can define Frame UOM
| Frame number start | Frame number end | Frame spacing | From UOM |
| -20 | 48 | 800 | m |
| 48 | 56 | 830 | m |
| 56 | 112 | 800 | m |
Depending on data in Frame systems, WA will generate
read-only data on the right side of the window.
