Force
External force acting on a drive train element as input signal
Modelica/Mechanics/Translational/Sources
The input signal "f" in [N] characterizes an externalforce which acts (with positive sign) at a flange,i.e., the component connected to the flange is driven by force f.
Input signal f can be provided from one of the signal generatorblocks of Modelica.Blocks.Source.
mo_useSupport | useSupport | = true, if support flange enabled, otherwise implicitly grounded | Number | 0 |
mo__modifiers/varname | Variable name | Cell of strings | 's' | |
mo__modifiers/value | Value |
flange | implicit | Flange of component | output | 1 |
f | implicit | Driving force as input signal | input | 1 |
Port 3 | implicit | Support/housing of component | input | mo_useSupport |
