SymmetricMultiPhaseWinding
Symmetric winding model coupling electrical and magnetic domain
Modelica/Magnetic/FundamentalWave/BasicMachines/Components
The symmetrical multi phase winding consists of a symmetrical windingresistor, azero inductor as well as a symmetricalmulti phase electromagnetic coupling and astray reluctance and acore loss model includingheat port.
See also
SinglePhaseWinding,SymmetricMultiPhaseCageWinding,SaliencyCageWindingRotorSaliencyAirGap
SymmetricMultiPhaseWinding_0
mo_m
m
Number of phases
Scalar
mo_useHeatPort
useHeatPort
Enable / disable (=fixed temperatures) thermal port
Number
0
1
mo_RRef
RRef
Winding resistance per phase at TRef
Scalar
mo_TRef
TRef
Reference temperature of winding
Scalar
mo_alpha20
alpha20
Temperature coefficient of winding at 20 degC
Scalar
mo_alphaRef
alphaRef
Scalar
mo_TOperational
TOperational
Operational temperature of winding
Scalar
mo_Lsigma
Lsigma
Winding stray inductance per phase
Scalar
mo_Lzero
Lzero
Zero sequence inductance of winding
Scalar
mo_effectiveTurns
effectiveTurns
Effective number of turns per phase
Scalar
mo_GcRef
GcRef
Electrical reference core loss reluctance
Scalar
mo_nBase
nBase
Number of base systems
Scalar
mo_mBase
mBase
Number of phase of the base systems
Scalar
SymmetricMultiPhaseWinding_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v'
'i'
'abs_V_m'
'arg_V_m'
'abs_Phi'
'arg_Phi'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
plug_p
implicit
Positive plug
input
1
plug_n
implicit
Negative plug
output
1
port_n
implicit
Negative complex magnetic port
output
2
port_p
implicit
Positive complex magnetic port
input
2
Port 5
implicit
Heat ports of winding resistors
input
mo_useHeatPort
Port 6
implicit
Heat port of core
input
mo_useHeatPort
See Also
