SignalMagneticPotentialDifference
Signal-controlled magnetomotive force
Modelica/Magnetic/FluxTubes/Sources
In electromagnetic devices, a change of a coil's magnetic flux linkage Ψ reacts on the electrical subsystem in that a voltage v is induced due to Faraday's law:
v = - dΨ/dt
This reaction can possibly be neglected for
  • modelling of electromagnetic actuators under quasi-static conditions (slow current change, slow armature motion),
  • modelling of current-controlled electromagnetic actuators (ideal current source) and
  • for system simulation where the system dynamics is not governed by an electromagnetic actuator, but by the surrounding subsystems.
In these cases, the magnetic potential difference or magnetomotive force imposed by a coil can easily be modelled with a signal-controlled source. Except for the neglected dynamics, steady-state actuator forces will be calculated properly in actuator models based on these sources.
SignalMagneticPotentialDifference_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'Phi'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
port_p
implicit
Positive magnetic port
input
1
port_n
implicit
Negative magnetic port
output
1
V_m
implicit
Magnetic potential difference
input
2
See Also
