DiodeBridge2mPulse
2*m pulse diode rectifier bridge
    DiodeBridge2mPulse
Modelica/Electrical/PowerConverters/ACDC
General information about AC/DC converters can be found at theAC/DC converter concept
This is a 2*m pulse diode rectifier bridge. In order to operate this rectifier a voltage source with center tap is required. The circuit topology is the same as inExamples.ACDC.RectifierBridge2mPulse. It is important to note that for multi phase circuits with even phase numbers greater than three theMultiStarResistance shall be used for grounding the voltage sources.
DiodeBridge2mPulse_0
mo_m
m
Number of phases
Scalar
mo_RonDiode
RonDiode
Closed diode resistance
Scalar
mo_GoffDiode
GoffDiode
Opened diode conductance
Scalar
mo_VkneeDiode
VkneeDiode
Diode forward threshold voltage
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
DiodeBridge2mPulse_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'vAC'
'iAC'
'powerAC'
'powerTotalAC'
'vDC'
'iDC'
'powerDC'
'LossPower'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
ac
implicit
AC input
input
1
dc_p
implicit
Positive DC output
input
2
dc_n
implicit
Negative DC output
output
1
Port 4
implicit
Conditional heat port
input
mo_useHeatPort
See Also
