IdealClosingSwitch
Ideal electrical closer
    IdealClosingSwitch
Modelica/Electrical/Analog/Ideal
The switching behaviour of the ideal closing switch is controlled by the input signal control: off = not control.
For further details, see partial model IdealSwitch.
IdealClosingSwitch_0
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
mo_Ron
Ron
Closed switch resistance
Scalar
mo_Goff
Goff
Opened switch conductance
Scalar
mo_useHeatPort
useHeatPort
= true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
IdealClosingSwitch_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v'
'i'
'LossPower'
'off'
's'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p
implicit
Positive electrical pin
input
1
n
implicit
Negative electrical pin
output
1
control
implicit
true => p--n connected, false => switch open
input
2
Port 4
implicit
Conditional heat port
input
mo_useHeatPort
See Also
