ControlledIdealCommutingSwitch
Controlled ideal commuting switch
Modelica/Electrical/Analog/Ideal
The commuting switch has a positive pin p and two negative pins n1 and n2.The switching behaviour is controlledby the control pin. If its voltage exceeds the value of the parameter level,the pin p is connected with the negative pin n2. Otherwise, the pin p isconnected the negative pin n1.
In order to prevent singularities during switching, the openedswitch has a (very low) conductance Goffand the closed switch has a (very low) resistance Ron.The limiting case is also allowed, i.e., the resistance Ron of theclosed switch could be exactly zero and the conductance Goff of theopen switch could be also exactly zero. Note, there are circuits,where a description with zero Ron or zero Goff is not possible.
Please note:In case of useHeatPort=true the temperature dependence of the electricalbehavior is not modelled. The parameters are not temperature dependent.
ControlledIdealCommutingSwitch_0
mo_level
level
Switch level
Scalar
mo_Ron
Ron
Closed switch resistance
Scalar
mo_Goff
Goff
Opened switch conductance
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
ControlledIdealCommutingSwitch_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'LossPower'
's1'
's2'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p
implicit
input
1
n2
implicit
output
1
n1
implicit
output
2
control
implicit
Control pin: if control.v > level p--n2 connected, otherwise p--n1 connected
input
2
Port 5
implicit
Conditional heat port
input
mo_useHeatPort
See Also
