Creating InfluxDB 2.x Output Connector
Allows periodical dumping of data from a Kafka topic into a time series database such as InfluxDB 2.x.
- On the Data Source tab, select Output > InfluxDB 2.x in the Connector drop-down list.
- Define or select the following properties:
Property Description URL
URL of InfluxDB 2.x.
Token
The generated token that will be used for authentication.
Organization
The organization where the token belongs.
Database
The name of the database that will be communicate over the HTTP(S).
Measurement
The table name that can be used as measurement.
- You may opt to use the toolbar to complete the data source definition.
- Click
. The new data source is added in the Data Sources list.
