Editing an Application
NOTE: Applications that are started or running cannot be edited.
- On the Applications tab, click an application link to modify.
The Application page displays.
- To change the Application Name, click on it to make it editable, then enter a new one and click
NOTE: The Name or ID must start with a letter (a to Z) or underscore. Also, it can only contain letters (a to Z), numbers (0 to 9), and underscores.
- You can also modify or add the following:
- Save the changes.
To go back to the Applications tab, click
beside the application name.NOTE: If there are changes that were not saved, a confirmation message displays asking if you will exit the Application page without saving. Click Cancel and then save.
