Adding an Operator
Operators can be added in any order. The sequence or direction of the graph will be based on the inputs or outputs that will connect the nodes.
When adding an operator, its node will be displayed in the Graph pane.
NOTE:
- The edges (inbound and/or outbound) will depend on the operator.
- For best practice, start by adding Input operators (i.e., Input, External Input, or Metronome) and end with the Output operator.
Also, the corresponding Operator Properties and Schema are displayed on the Application page.
