Creating Kx kdb+ Output Connector
Allows periodical dumping of records from a Kafka topic into a Kx kdb+ connector.
  1. On the Data Source tab, select Output > Kdb+ in the Connector drop-down list.
  2. Define or select the following properties:
    Property Description
    Host
    Kx kdb+ host address.
    Port
    Kx kdb+ host port. Default is 5001.
    TLS Enabled
    Ensure to check if you have started q with TLS only.
    User Id
    The user Id that will be used to connect to Kx kdb+.
    Password
    The password that will be used to connect to Kx kdb+.
    Table
    The source table.
    NOTE: These properties can be parameterized.
  3. You may opt to use the toolbar to complete the data source definition.
  4. Click  . The new data source is added in the Data Sources list.
