Creating InfluxDB 1.x Output Connector
Allows periodical dumping of data from a Kafka topic into a time series database such as InfluxDB 1.x.
- On the Data Source tab, select Output > InfluxDB 1.x in the Connector drop-down list.
- Define or select the following properties:
      Property Description URL URL of the InfluxDB 1.x. Port The port running the InfluxDB 1.x HTTP service. Default is 8086. Database The name of the database that will be communicate over the HTTP(S). User Id The user Id that will be used to connect to InfluxDB 1.x. Password The password that will be used to connect to InfluxDB 1.x. Measurement The table name that can be used as measurement.
- You may opt to use the toolbar to complete the data source definition.
- Click  . The new data source is added in the Data Sources list.
