Connector for Text (Legacy)
The Text connector allows the retrieval and processing of delimited Text files (such as CSV, TSV, and so on), either from a disk or from a defined URL.
  1. Select the Text File Source.
    NOTE:
    The Upload File button, when clicked, allows the user to choose files from their own computer. To choose files that resides on the Panopticon Server machine, use the Link to File option and fill in the Text File Path.
    The standard settings controlling how the text file is parsed, is listed. These include the following:
    Property Description
    Skip First N Rows
    Specifies the number of rows that will be skipped.
    Data Type Discovery
    Specifies how many rows from the text file should be used when automatically determining the data types of the resulting columns.
    Decimal Separator
    Select either the dot (.) or comma (,) as the decimal separator.
    File Encoding
    Set the character encoding to use in text data.
    • UTF-8
    • UTF-16
    • UTF-16BE
    • UTF-16LE
    • US-ASCII
    • Windows-1252
    Text Qualifier
    Specifies if fields are enclosed by text qualifiers, and if present, to ignore any column delimiters within these text qualifiers.
    Can be any of the following options:
    • None (Default)
    • Single Quote
    • Double Quote
    Column Delimiter
    Specifies the column delimiter to be used when parsing the text file.
    • Comma {,} (Default)
    • Semi colon {;}
    • Pipe {|}
    • Space
    • Tab {t}
    • Other
    First Row Headings
    Determines if the first row should specify the retrieved column headings and not be used in data discovery.
  2. Click   to the fetch the schema based on the connection details. Consequently, the list of
    columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
    By default, all the generated columns are enabled. You can uncheck the Select All box, then check the boxes of the columns that will be enabled.
  3. You can also opt to load or save a copy of the column definition.
  4. Click    to add columns and specify their properties:
    Name
    Column Index
    The Column Index of the source schema.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    To delete a column, select  or for all the column entries select the topmost , then click .
  5. Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
