Connector for Altair IoT Studio
The Altair IoT Studio connector allows reading/writing data from Altair IoT Studio. This dedicated connector is recommended over the standard Web Data connector since it can automatically iterate over all the available data from service using iteration over cursor in the response. The UI also allows minimal settings required to connect to the Altair IoT Studio OpenAPI endpoints.
NOTE:
To use this connector, you need to set the connector.iot_studio.url property in Panopticon.properties. This is the full API URL to the server running Altair IoT Studio.
For example:
connector.iot_studio.url=https\://api.swx.altairone.com
  1. Select one from the following Operations:
    • Get the status of all the things from a category
    • Get properties values of a specific thing
    • Get historical values of the all the properties of a specific thing
      NOTE:  For this operation, you should limit the query string in URL to avoid too much data. The default value for limit is 50 inside IoT Sudio API.
    • Manage data through HTTP
    • Run a custom query
    The corresponding properties of the selected Operation are discussed below:
    Property Description
     Category Name
     The name of the category that will group your things in a logical way.
    Scope
    The request parameter while retrieving OAuth token.
    URL
     Path for the following options:
    • Get the status of all the things from a category (i.e., /spaces/{space-id}/categories/{category-name}/things?limit={limit})
    • Get properties values of a specific thing (i.e., /spaces/{space-id}/things/{thing-id}/properties)
    • Get historical Values of the all the properties of a specific thing (i.e., /spaces/{space-id}/things/{thing-id}/properties-history?limit={limit})
    Record Path
    When loading JSON data, the Record Path can be suggested automatically by pressing the Fetch button. The default is data. However, for the Run a Custom Query operation, the default is result.
    Array Handling
    Determines how the data table will be created to accommodate the array of values.
    Thing ID
    The ID of the thing or asset.
    HTTP Method
    The appropriate HTTP method for the request with the following options:
    • GET - To retrieve data.
    • POST – To add new data.
    • PUT – To replace existing data.
    • DELETE – To remove existing data.
    Request Headers
    Custom Request Headers which enable connection to the API of AnythingDB.
    Request Body
    The request body to be supplied to the HTTP call.
    Path
    Path for the Run a custom query operation: /spaces/{space-id}/query/cursor
  2. Under the Connection section, enter Space ID, Client ID, and Client Secret to connect to Altair IoT Studio.
  3. Select the Timeout which is the length of time waiting for the server response (10 to 300). Default is 10.
  4. Click    to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
  5. You can also opt to load or save a copy of the column definition.
  6. Click   to add columns and specify their properties:
    Name
    JsonPath
    The JsonPath of the source schema.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    To delete a column, select  or for all the column entries select the topmost , then click .
  7. Click to test the connection. When successful, displays.
  8. You can control the total number of rows and cursor iteration using the Row Limit section for the operations.
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
