Automator Contacts
Use the Automator Contacts page to add, edit and delete contacts.
To access the Automator Contacts page
On the Navigation Tree, click System Settings, and then select System Preferences.
At the top of the page under Automator Settings, select the Automator Contacts tab.
To add a new contact
On the Automator Contacts page, click the Add icon
On the displayed page, specify the following information:
Name: Enter the contact name.
Email: Specify email.
Click the Save button.
To edit a contact
On the Automator Contacts page, do one of the following:
Click the name of the contact you want to change or click anywhere on its row, and then click
Make necessary changes. For details see, Adding a New Contact.
To delete a contact
On the Automator Contacts page, select the contact you want to delete.
Click
at the end of the row with the contact you want to delete. A dialog box appears.
Click Delete to remove the contact from the list.
