Visual Process Designer
The Visual Process Designer tool allows you to create processes in easier and more convenient way than to apply the standard approach. You have full set of tools for process creation that is used in standard processes but you have greater capabilities to apply these tools and therefore set up more sophisticated scenarios.
Data acquisition, conversion and distribution is visualized in the Process Designer through use of graphic elements and connectors arranged by threads.
By using library of graphic elements and a workspace, you can quickly assemble different process components to set the required process. The created process can be represented as a graph in the Process Designer window.
Visual Process Designer interface
The Visual Process Designer interface consists of the upper line, Process Designer Library, Workspace panel, and Properties panel.
The upper line of the Process Designer contains name of the process (on the left) and the Designer Toolbar. You are allowed to change name of the process if needed.
The table below specifies buttons of the Visual Process Designer toolbar.
Button Name |
Description |
New |
Click to open new workspace for creation new process. The workspace with the previous process will not be saved automatically. |
Save |
Click to save the specified work flow as a process. |
Save as ... |
You can choose the following options:
Insert Template |
Click to open the list of existing templates. You can select the required template and add it to the workspace. |
Insert Process as Group |
Click to open the list of existing processes. You can select the required process and add it to the workspace as a group element. |
Triggers |
Click to specify when the process will run. You can choose the following types of process triggers:
Only one of them can be chosen at a time. Schedules TriggerA schedule is used to specify when, and at what interval the process will run. You can create a number of schedules but their launch time must differ. NOTE: If the Config service is not available and you are using Altair licensing, Automator processes will be switched to "Limp Mode." In this mode, you can run only one process (i.e., one Standard Process and one Visual Process) every hour. Moreover, you cannot run a Visual Process that involves other Standard or Visual Processes. Limp Mode is deactivated once the Config service becomes available.
To add a new schedule for a process:
To delete a schedule:
Select the Suspend check box to temporarily hold up the trigger. Inputs Monitoring TriggerWhen you specify inputs monitoring settings for a process, you specify files that you want Automator to monitor a particular location for. When the file arrives in the specified location, Automator will trigger running of the associated process. NOTE: Changes in monitoring settings, including enabling and disabling monitoring or changing paths for monitored folders, take effect after approximately 1 minute. To specify an inputs monitoring file
NOTE: If you're unsure of the file's exact name or if you want Automator to monitor for any file of a particular file type, you can use a wildcard character, either an asterisk (*) or a question mark (?), so that the arrival of any file of the specified type will trigger the running of the process. An asterisk may replace multiple characters while a question mark may replace any single character.) For example, adding *.prn to the end of the folder path instructs Automator to trigger the running of the associated process when any report file with a .prn extension arrives in the specified location. You may also use the naming macros to specify the file path (for local and named paths). Click the Insert Macro icon
To delete an inputs monitoring file
Manifests Monitoring TriggerWhen you specify manifests monitoring settings for a process, you specify the manifest XML files that you want Automator to monitor a particular location for. When the file arrives in the specified location, Automator will trigger running of the associated process. To specify a manifests monitoring file
NOTE: If you're unsure of the file's exact name or if you want Automator to monitor for any file of a particular file type, you can use a wildcard character, either an asterisk (*) or a question mark (?), so that the arrival of any XML file will trigger the running of the process. An asterisk may replace multiple characters while a question mark may replace any single character.) You may also use the naming macros to specify the file path (for local and named paths). Click the Insert Macro icon
To delete a manifests monitoring file
Report Warehouse TriggerThis trigger is available only if in the Monarch Server License the Enterprise Server component is enabled. It enables you to specify certain document types so, when the system receives a report with the corresponding document type, the trigger runs a process. To assign Report Warehouse document types
You can also add document types from the Report Warehouse Input of the current process by clicking the Assign from process button. Select the Disable Triggers check box to temporarily turn off all triggers. |
Scripts |
Click to apply scripts to the current process. In the Process Declarations tab, the following settings are available.
In the References and Imports tab, specify additional assembly references and namespaces that are required by PostExport, PreExport, and Global Declarations sections. The following settings are available:
Generate Manifest File |
Click to create a manifest XML or JSON file that is based on the settings of the visual process. The created XML/JSON file can be used immediately to initiate process runs. In the Manifest window, select the preferred manifest file format:
NOTE: This icon is available only after the visual process is saved. Before starting a process with a manifest containing some passwords, make sure to specify all required passwords and uncomment the “TODO:Specify Password” row in the manifest. If the process has no passwords, the manifest file generated automatically could be retained as it is. |
Alerts |
Click to view, add, edit, or remove alerts for the current process. In the Process Alerts window, click the Add icon
NOTE: This option is available only when the Allow ignore Global alerts setting is enabled. See Automator Settings for details.
NOTE: The Rise Alert Immediate checkbox is available only for the SystemAlertNoInputToExporter alert and the SystemAlertProcessElementFailed alert.
Save and Run |
Click to save the project and launch its execution. |
Stop |
Click to cancel the execution of the project. |
Auto Arrange |
Click to let the Process Designer arrange graphic elements intuitively on your workspace. |
Zoom In (+) |
Click to increase the size of some workspace area so that you can focus on areas of particular interest. |
Zoom Out (-) |
Click to decrease the size of some workspace area so that you can return to a larger scope. |
Clear |
Click to clear Visual Process Designer workspace |
Log Mode |
Click to open the Log Mode view. For a new process that has not been run yet, there are no logs available. Otherwise, the Log Mode view shows the results of the last run of the current processes. The Log Mode allows visual elements to be edited, along with their respective settings. After changes are made, click the Save and Run icon to actualize your changes by running a process with updated settings. Click Stop to cancel the execution of the process. Process Events displays general information about the recently run process, including the start and end times. Process Items allows you to filter the process information by selecting and clearing the following check boxes:
Click the n Events link below each file source to expand the relevant information, including the start and end times. The items may be sorted according to duration (ascending and descending), start time (ascending and descending), and type. Click the Export Log button Click the Designer Mode icon to leave the Log Mode view. |
Process Global Settings |
Click to modify the workspace validation settings of the Visual Process in the Process Global Settings window. Select the Disable Validation checkbox to turn off the workspace validation for the loaded Visual Process. NOTE: This setting has higher priority than the workspace validation setting in Automator General Settings. |
Rights |
Click to assign process access rights to other users, roles, or groups. NOTE: See Application Settings for more details. |
Help |
Click for information about basic and advanced Visual Processes. |
Close |
Click to close Visual Process Designer |
Major part of toolbar controls can be called using the context menu. The Process Designer context menu is called on the right click on the workspace area. You can use the following commands from the Process Designer context menu:
Insert Template
Auto Arrange
Zoom In
Zoom Out
Show/Hide Grid
Enable Auto Connect
Show advanced connectors
Clear
The context menu is also available for all graphic elements. You can use the following commands from the element context menu:
Duplicate — to duplicate the selected element.
Group — to combine several selected elements into a single element group (available for multiple selected elements only).
Ungroup — to revert elements grouping (available for selected group elements only).
Drill in — to open the group element (available for group elements only).
Rename — to rename the selected element.
Delete — to delete the selected element.
Properties — to open properties of the selected element.
On the left panel, there is a Process Designer Library with graphic elements to denote different types of inputs, models, exporting jobs, prerequisites, etc. All items from this library can be used to assemble the required process.
To the left of the Process Designer Library, the Workspace panel is adjusted to where you can drag and drop graphic elements from the Library panel.
Single or double click on a particular graphic element opens panel with its properties. When displayed, the Property panel is located on the right part of the Process Designer window. Mandatory buttons of the Properties panel are as follows:
Ok — to save the changes made on the Properties panel and close the panel.
Apply — to save the changes made on the Properties panel and leave the panel to be expanded.
Cancel — to cancel the changes made on the Properties panel.
NOTE: When you do not click Ok or Apply in the Property panel and you click on another graphic element in the Workspace panel, a dialog box appears to warn you about losing unsaved changes. In the dialog box, you can choose to save or not save the changes you have made in the Property panel. Clicking Cancel will close the dialog box, and the Property panel will remain open.
The Process Designer Library contains the following groups of the graphic elements:
Some library elements define the process work flow, and some not. For example, library elements from the Input and Model groups represent data, but not work flow.
Process work flow is defined by graphic elements in the following library groups:
Exports
Prerequisites
Misc (with the exception of the Credential element)
Output
Elements from the Input and Model groups do not define process work flow. Belonging to work flow is a benchmark why two types of connectors are used, namely:
Solid line connectors — for connecting work flow items
Dashed line connectors — for connecting non-work-flow items.
One more work flow (not data) indicator for a graphic element is availability of input and output pins of gray color on the element's icon ().
Connectors differ by color:
Gray connector — implementation of work flow stage is successful
Red connector — implementation of work flow stage leads to failure
Quick adding the connected elements
Quick connectors are available upon mouse over an element — two plus signs (+) appear on top of it.
Left plus connector — allows to promptly select and add another input element connected to the current one.
Right plus connector — allows to select and add an output connected element.
NOTE: Quick connector buttons for workspaces with selected settings of load plans and input files allows to select and add a connected input file element (unpinned input files only).
Group element
You can open the group element by right-clicking and choosing Drill In, or by double-clicking the element. After opening, the breadcrumbs line displays the group name.
If you want to exit the group, click the previous element in the breadcrumbs line.
You can add new elements to the group element by dragging and dropping.
You can connect the group element with the required element by dragging the connector icon from the group element to the required element. Also, you can connect the required element with an element of the group. After that, you can open the group element and proceed with connecting it to the necessary element in the group (the icon of that connection is selected and the name of the connecting element is displayed in the tool tip).
Instructions for process work flow building
There are no mandatory graphical elements that must be used for work flow building.
Starting work flow item is defined by absence of input connector. Process execution starts with the starting work flow item.
Final work flow item is defined by absence of output connector. Process execution finishes on processing final work flow item.
If there two or more starting items, execution starts synchronously and is divided in two parallel threads.
You can fork work flow using connectors if you need to branch one thread of process execution into two or more parallel threads.
Successful execution of work flow stage is defined by gray connector, unsuccessful execution of work flow stage is defined by red connector.
By pop-up colorful arrows, the Process Designer gives prompts that some work flow items are available for connecting with the particular item and some work flow items cannot be connected with the given item.
By pop-up single/double arrows, the Process Designer gives prompts that a particular work flow item can be connected with the single item only or with multiple items.
For export operations, output work flow item can be an input item for subsequent work flow item.
NOTE: A Visual Process can be run in parallel with itself. This feature is useful in specific cases, e.g., those initiated by a manifest file with different inputs and outputs for each process run or when a macro output is used according to different input file names.
However, running the same Visual Process in parallel could lead to resource contention. This feature does not include any mechanism for locking inputs or outputs if they simultaneously appear in more than one instance.
Every time you run a process, process log item is created. Refer to the Process Logs section for details.
If you save some process as a template, it will be saved in the list of templates and could not be found in the list of processes. In this case, settings for all data flow items will not be saved.
