Model Elements
Model elements in the Process Designer tool are sets of instructions how input files are parsed by Automator.
A model file, created within Monarch, is a file with the .dmod or .xmod extension that may contain field, filter, summary and chart definitions as well as other settings. This information can be viewed by clicking the information icon below the Model Path field.
The table below specifies the functionality of each Model element.
Element Name |
Description |
Properties and Comments |
File Model |
Model file with the .dmod or .xmod extension |
The Model Path parameter can be filled out manually or using Browse.
NOTE: Model files in compressed archive format (e.g., zip and gzip) can be used and specified.
Web Model |
Model file located in the web |
NOTE: If some web model file requires authentication, you should add the Credentials element and connect your Web Model element with it. In properties of the Credentials element you should specify the User Name and Password parameters. |
Server Library Model |
Model within a database |
NOTE: For external lookup from a password-protected Excel file, select the External Lookup checkbox and enter the password of the Excel file in the field provided. When executing processes with external lookup, the following error message is displayed in the logs when the external lookup data source in the model is missing or invalid: An external lookup data source ‘path_to_the_external_lookup’ is either missing or invalid. |
