Adding a Visual Process
To add a Process
On the Navigation Tree, click Automator and select Visual Processes.
On the Processes page, click the Add icon
. The Visual Process Designer interface will be displayed.
Choose Blank Process to work on a Visual Process from scratch. To use a template, you may choose from the following:
Data Prep
Distribute export result
Groups
Model verify
Parallel export
Script
Sequential export
